Activity Forums Adobe After Effects How do I change parts of a moving object?
  • How do I change parts of a moving object?
    Posted by Jardley Jean-louis on October 21, 2015 at 6:00 pm
    I’ve got a character who is running, and i’d like to change his outfit at a certain point without redoing the keyframing. I’ve got both outfits done in illustrator and have tried alt-dragging the 2nd outfit onto a duplicate of the 1st animation precomp but instead of pasting in place it paste whereever it wants in the frame.
    I’m looking for this exact effect:
    https://vimeo.com/134296937
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Jardley Jean-louis replied 10 years, 10 months ago 3 Members · 3 Replies
  • Frank Feijen
    October 22, 2015 at 7:40 am
    Maybe you could precomp the layer? Do the transition in the precomp.
  • Ashish Gupta
    October 22, 2015 at 8:58 am
    This can happen if the resolution of your precomp and the 2nd outfit layer is different.
    Instead of trying to replace the outfit with the precomp you should replace it with the output layer inside the precomp.
    If it’s still creating problems you can change the anchor point property to bring it to the desired position without having to keyframe again.
    Ashish Gupta
    Motiongraphics artist and 3d generalist
    aashi.29nov@gmail.com
  • Jardley Jean-louis
    October 22, 2015 at 10:10 pm
    I’ve found the solution thanks.
