Activity › Forums › Apple Final Cut Pro Legacy › How do I capture a still Frame in video in FCP HD?
  • Peter
    May 26, 2005 at 12:26 pm
    Capture the video as you normally do.
    Go to export>Quicktime Conversion
    Select “still image”
    It defaults to PNG but I always change it JPEG.
    Come to think of it, why is the default PNG? Is that the best way to go? I’ve had problems opeing PNGs in Photoshop in the past so I started with JPEGs.
  • Pdr
    May 26, 2005 at 1:32 pm
    Hi folks
    Here is a nice little workflow I’ve learnt, and like to use for exporting multiple stills; saves quite some time as it utilises the Batch Export feature of Final Cut Pro. I picked it up from someone somewhere on an FCP forum, so kudos to you — and apologies for not remembering who it was. Remember: imitation is the highest form of flattery.
    In the Browser, I select the clips I want stills for, and add markers to them in the Viewer. I even add meaningful labels to the markers, so I know which still is which.
    When complete, I flip the disclosure triangles for each of these clips in the Browser, which reveals all the markers, and their names.
    I then launch the Export Queue window, via the menu Window > Export Queue
    I select all the markers, and drag them onto the Export Queue.
    I then click Settings, and set the following:
    – Destination for exported stills
    – Format: Still Image
    – Settings and Options — file format and compression settings as you prefer
    — I personally like .png, as they are compressed, but not filled with artifacts
    Click OK.
    Click Export.
    Voila! All your stills are exported.
    Hope this helps.
    Regards
    Peter
    Peter Dominic Ryan – Freelance Editor
    raycity* media – pdr@raycity.com
    PowerMac G5 Dual 2.0 GHz, 4GB, Mac OS X 10.4
    FCP 5, Soundtrack Pro, Motion 2, DVD SP 4
