Activity › Forums › Apple Final Cut Pro Legacy › how do I batch send to compressor from FCP?
  • how do I batch send to compressor from FCP?
    Posted by Roli Rivelino on June 6, 2011 at 5:44 am
    I’m sure you can do this, but I can’t work out how, I just want to send a few jobs from inside FCP to compressor all at once, put the same codec on them and just let it run.
    Many thanks
    https://www.rolirivelino.com/
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
    Dustin Kincaid replied 15 years, 1 month ago 3 Members · 5 Replies
  • Everest Mokaeff
    June 6, 2011 at 6:24 am
    Command/Shift select all sequences/clips in FCP browser then send them to compressor as separate sources. In compressor you’ll have one batch with your sequences/clips as separate works. Apply approproate targets to them and you’re good to go.
    Free-lance fcp editor in Moscow
    http://www.mokaeff.com
  • Roli Rivelino
    June 6, 2011 at 9:15 am
    Cool, thanks Everest, saved me lots of time.
    System
    8Gb RAM
    Equipment
    Firestore FS-100
  • Dustin Kincaid
    August 16, 2011 at 1:25 am
    Does anyone else have an issue with this process?
    This has been my method of exporting for about two years, and there seems to be a bug in compressor.
    All my videos will get exported the same length with this process (the length will be determined by the first sequence sent to compressor).
    Example:
    50 timeline edits – all different durations, right click in FCP and send all of them to compressor – no intermediate encode. (Requires final cut on every cluster machine).
    The 50 entries will get added to one compressor batch with 50 jobs – (after you select “export as separate sources” – not merging).
    Then, apply the presets and submit to the cluster… (you would think)
    BUT…
    Whatever the first job entry in compressor seems to determine the length of rest of the videos in the batch. If the first video is longer than the rest, the rest have black footage added until it hits the same timecode, if the rest are shorter, they truncate at the duration of the first video (or a mixture of both scenarios).
    I’ve tried reinstalling everything completely from the ground up, doing the same exact thing with a stock Apple template (so I know there’s nothing weird with my custom templates).. yet it still does this.
    My workaround is to remove every job entry in the large batch and put each its own individual compressor batch (very time consuming) or send each individual timeline to compressor separately (again, very time consuming).
    With my workflow, I need to send 100’s sometimes 1000’s of timeline edits at once to compressor to have it render on about 12 machines. Encoding to a intermediate file is not an option.
    Any ideas?
  • Roli Rivelino
    August 16, 2011 at 9:05 am
    I don’t get this problem, when I used the solution above everything worked fine.
    System
    8Gb RAM
    Equipment
    Firestore FS-100
  • Dustin Kincaid
    August 16, 2011 at 5:04 pm
    It’s weird, it’s a problem with this workflow.
    see
    https://forums.creativecow.net/thread/8/1124774#1124774
    The solution given there is kind of a no brainer, but not an option when you’re working with terrabytes of data (and it defeats the purpose of having multiple compressor nodes), if I have to batch export on one machine first, I may as well call it a day and be done with it right there – but it would take weeks on one machine.
    The workaround (for me) is send in smaller batches and move each job into its own batch. Which as you can imagine is very tedious and almost impossible to manage with the way compressor 3.5 is designed. You can only see so many tabs and it doesn’t let you scroll.
    I just want to confirm that it exists and see if anyone else has run into this problem.
    Some times its not too big of an issue if my sequences are all the same length… then I keep them all in one job batch and send it like it’s supposed to work. It’s just very difficult if they are all different durations.
