Activity Forums Adobe After Effects How do I avoid s-like curve when easy easing the keyframes of a scale and position change of a logo?
  • How do I avoid s-like curve when easy easing the keyframes of a scale and position change of a logo?
    Posted by Spazz Nielsen on February 24, 2012 at 4:46 pm
    I’m changing the position as well as scale of a logo from the center (in big) to the right upper corner (as small). To ease the start and end of the scaling and position change I use easy ease interpolation. When I look closely at the result it looks as if the curve of the position isn’t linear but its moving in a bit of a S-like curve. How do I avoid this when I want the position change to start and and stop slowly and keeping a straight linear moving curve to the corner?
    Darby Edelen replied 14 years, 7 months ago 2 Members · 2 Replies
  • Spazz Nielsen
    February 24, 2012 at 5:25 pm
    The motion path.
  • Darby Edelen
    February 25, 2012 at 6:03 pm
    You can directly edit the keyframe points of a motion path in the composition or layer view with the pen tool. This works just like editing regular mask vertices.
    So with the pen tool you can opt-click (alt-click on pc) the keyframe points to convert them to linear.
    Darby Edelen
