Activity Forums Maxon Cinema 4D How Do I Animate A Feather Object?
  • How Do I Animate A Feather Object?
    Posted by David Chabashvili on August 15, 2009 at 3:24 pm
    Need help here… I have a made a feather as per this tut (https://www.c4dcafe.com/ipb/index.php?autocom=downloads&showfile=574).
    I have several of these feathers made and I want to animate them in a way that their roots are staying at one place and just tops are moving – like when a bird is opening its wings.
    I have also set up the respective bone system with joint tool and the problem is that when I try ti Bind the rigging to the SweepNurbs (which includes the Feather Object as per tutorial), I cant – the Bind is grayed out in the menu.
    After that first I made editable the feather object, and only after that the SweepNurbs object, as the result I got a polygon object (any other way to make this feather editable led to the disappearance of feathers). Now I can Bind the rigging to the new feather polygon but only the spline is animated and the feather object (which now has become a hair guide) does not move at all.
    So my question is:
    Is there any way to animate the Feather like this one?
    Is there any other way to make poly without making feathers disappear?
    What am I doing wrong?
    Thank you in advance.
    David Chabashvili replied 17 years ago 1 Member · 0 Replies
  • 0 Replies
