Activity › Forums › Maxon Cinema 4D › How do I add to a selection?
Posted by Joseph M. morgan on March 9, 2008 at 1:40 amI have a really complex floor plan and am adding materials to it’s surfaces. I missed some windows during my selection. How to I add elements to a selection?
Joe
Peter Catigay replied 13 years, 8 months ago 4 Members · 5 Replies -
Brian Jones
March 9, 2008 at 2:26 amYou’re adding to a selection tag, yes? Select the Selection Tag hit Restore Selection add your windows to the selection, then with the selection tag still selected choose Set Selection again.
Rachael Balascak
November 22, 2011 at 5:01 pmHello, I am trying to do the exact same thing, however i do not see the “Set Selection” button.
I am in the Broadcast edition, is that why?
thanks
-rachael
Brian Jones
November 23, 2011 at 12:37 amI think Set Selection is in all versions. It should be in the Select menu or in the Select menu in the V popup. You’d need to have an editable object selected and be in point/edge/poly mode…
