Activity Forums Avid Media Composer How Do I Add Filler Between Two Clips on Timeline?
  • How Do I Add Filler Between Two Clips on Timeline?
    Posted by Gabrielle Mitchell on June 20, 2016 at 10:04 pm
    Hi, I’m wondering if someone could help me find the “add filler” option in AVID 8.3.1. I don’t want to add filler to the beginning of a sequence but between two clips. Thanks for any help.
    Where there is no struggle, there is no strength.
    Glenn Sakatch replied 10 years, 2 months ago 4 Members · 3 Replies
  • Stacy Lincoln
    June 21, 2016 at 12:00 am
    You should be able to insert the filler anywhere. Set an “in and out” when you call up filler and hit the yellow insert arrow key. If that doesn’t work….make a quick “title” in the title tool and insert that.
  • John Pale
    June 21, 2016 at 12:18 am
    “Load Filler” in the source monitor. Insert Edit between two clips.
  • Glenn Sakatch
    June 23, 2016 at 7:05 pm
    even more specifically. Right click on your source monitor and select load filler.
    Glenn
