Activity Forums DaVinci Resolve How do I add a Broadcast Safe?
  • How do I add a Broadcast Safe?
    Posted by David Scott on September 20, 2012 at 9:53 am
    Hi there
    I’m editing a rock concert with lots of nice bright coloured lights.
    It’s in PAL ProRes 720×576 anamorphic.
    I want to keep the punch but then add a broadcast safe to legalize it. In FCP I just drop on a filter… in Color there is a tick box… what’s the procedure in Resolve for doing this? I’ve got thousands of shots and really don’t want to have to individually tweak the saturation curves for each one!
    I’ve seen some posts suggesting using a LUT so I tried adding to my last node “1D Output LUT – Datatovideoscale”… which successfully clamped the chroma and highlights, but then also lifted the black levels 10% so the blacks were gray!?!
    Am I right to use a LUT? And how do I stop it lifting the blacks?
    Many thanks
    David Scott,
    Senior Editor,
    GOD TV (UK)
    Liam Ward replied 13 years, 10 months ago 3 Members · 3 Replies
  • William Edwards
    September 23, 2012 at 4:50 am
    On the render tab, right before you output, there’s a box that you can select full range data or broadcast levels. No need to add a LUT, which I don’t think would really help anyway.
  • David Scott
    October 8, 2012 at 12:33 pm
    Thanks William – found it!
    Strange it only limits the luminance and not also chroma levels?
    David Scott,
    Senior Editor,
    GOD TV (UK)
  • Liam Ward
    November 7, 2012 at 2:26 pm
    [David Scott] “Strange it only limits the luminance and not also chroma levels?”
    This is true, currently there is no way to limit the chroma levels inside resolve.
    Liam.
    Liam Ward
    Sinking Ship Entertainment
