Activity Forums Adobe Illustrator How do I achieve a subtle gradient on all 4 sides of a rectangle?
  • How do I achieve a subtle gradient on all 4 sides of a rectangle?
    Posted by Heavythinker on August 16, 2006 at 12:13 am
    Hi all-
    I am using Illustrator CS2 and cannot figure out how to achieve a subtle gradient for my menu bar that has a slight fade around every side of each menu button. Please see an example here. https://videoenrichment.com/menubar.jpg
    I want different colors but the same type of effect. I have been playing with the gradient tool but can’t make one that has the slight fade at all 4 angles (only either vertical or horizontal but not both)
    Can someone please help?
    Nicole
    Mike Gondek replied 20 years, 1 month ago 2 Members · 1 Reply
  • Mike Gondek
    August 17, 2006 at 9:46 pm
    Draw your shape adn fill with a color. Thenuse object >> make gradient mesh. Select gradient mesh points with the hollow arrow tool, and you can change their color individually or reporition them.
