Activity Forums Apple Final Cut Pro Legacy How do defeat keyboard volume control
  • How do defeat keyboard volume control
    Posted by Bob Flood on April 5, 2006 at 1:17 am
    Hello Again
    So my apple keyboard volume control affects my kona lh output level. is there anyway to disble this? if not how many dots should i run it at?
    thanx again
    bee eph
    Bob Flood
    Greer & Associates, Inc.
    Hans Vernhout replied 20 years, 5 months ago 5 Members · 5 Replies
  • Tony! Hulette
    April 5, 2006 at 1:25 am
    Have it turned all the way up (full dots).
    Tony!
  • Jeremy Garchow
    April 5, 2006 at 1:28 am
    You need to set up your kona properly and now you have given control of the OS to your Kona board. Not recommended, at least I don’t as it can really screw you up, as you are finding.
    Read this:
    https://www.aja.com/pdfs/KONA2_Audio_FAQ.pdf
    This was written for the Kona 2 but should apply to you as well.
    If you want to hear your system sounds through your monitor speakers, simply run the headphone out of your G5 into your mixer.
    Jeremy
  • Les Kaye
    April 5, 2006 at 5:54 am
    Bob you can also disable the volume “beeps” if that’s what’s bothering you.
  • Bob Flood
    April 5, 2006 at 12:31 pm
    thanx les and all
    it was more about making sure i was doing all the right gain staging between kona, my mackie mixer, beta etc
    I know i can reconfigure so only fcp uses kona, but i also need to hear other apps that do not path directly to kona, such as qt, dvd studio, playboy etc. (ha ha on the last)
    I went to the doc on kona audio as suggested, and on my system i get no percentages so i have to ball park the fader in the mac sound control pane as suggestedm which corresponds to 11 dots
    bee eph
    Bob Flood
  • Hans Vernhout
    April 7, 2006 at 6:24 am
    Bob,
    You can see the percentages when you pause your mouse pointer over the slider control in the volume slider.
    Hans Vernhout
    Director / lighting cameraman
    The Netherlands
