Activity Forums Maxon Cinema 4D How could I mask/disable or hide polygons based on a region/bounds?
  • How could I mask/disable or hide polygons based on a region/bounds?
    Posted by Jack Daniels on December 22, 2018 at 6:10 pm
    I’m using the displacer deformer with an imported mov video that serves as a fake ‘depth’ map. In my source video ,I masked out areas I don’t want to use, and they’re solid black. With the deformer tag, the fake ‘depth’ map works as I want, but the masked out black regions of the source video create a solid plane, and I’m wondering if there’s a way to create a region, such as a falloff to hide/disable these polygons. The result should be only polygons that are affected by the displacer tag.
    If there’s a way I could do this, possibly with xpresso, let me know if you have any ideas.
    Brian Jones replied 7 years, 9 months ago 2 Members · 1 Reply
  • Brian Jones
    December 23, 2018 at 12:17 am
    you should be able to use the same mov in the Alpha channel of a material on the object. Play with the Black Point/White Point values to get 0% alpha in the areas you want to be seen.
