Activity › Forums › Adobe After Effects › How come when I do text…
  • How come when I do text…
    Posted by Stylz on April 26, 2005 at 5:04 am
    the text does not look smooth. Looks pixelated even at %100.
    I see demo reels with perfectly smooth text.
    I use after effects text. Do I need to use a outside program for text?
    Is it because my composition is dv ntsc and not square so it looks pixelated on my computer monitor?
    Thanks in advance.
    Stylz replied 21 years, 4 months ago 3 Members · 3 Replies
  • Michael Szalapski
    April 26, 2005 at 11:19 am
    First of all make sure you’re using a smooth font. 🙂
    If you are then make sure your layer is set to best quality and your composition window is set to full resolution.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great)
  • Filip Vandueren
    April 26, 2005 at 1:06 pm
    If you have pixel aspect correction on, then the type will look awfull on the screen, but it will look ok when you export it to a tape.
    It’s the icon in the previex windox to the right of “Active Camera”
  • Stylz
    May 12, 2005 at 10:32 am
    I figured it out. Anyone who searches this topic, ensure you are set for dv-ntsc 4:3. More importantly make sure you field render(lower first for ntsc).
