Activity Forums Adobe After Effects How come my picture’s dimension are distorded
  • How come my picture’s dimension are distorded
    Posted by Anilio Sweet on December 3, 2011 at 12:25 pm
    Hai guys and girls,
    Sorry mayben it doenst maken sence but i have a litlle problem.
    I have a comp, pal widescreen 1080 x 720
    I have noiced that if i put a picture in the comp it gets disorded, i.e. i have a triangle the size is the same 350 x 350 x 350 But when i put it in the comp it isnt any more same size..
    Same with other pictures.. dont now why ??
    Anilio Sweet replied 14 years, 9 months ago 3 Members · 6 Replies
  • Tudor “ted” jelescu
    December 3, 2011 at 9:47 pm
    I am unclear- pal widescreen 1080×720? Did you mean to say 1280×720, 25 fps, square par OR 1050×576 @25fps widescreen par (PAL SD widescreen)?
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Anilio Sweet
    December 3, 2011 at 9:53 pm
    sorry yes 1280 x720 palwidescreen scuare
    December 3, 2011 at 9:56 pm
    The only idea I have is that somehow your pixel aspect ratio for the comp or the graphic/footage you see distorted may not be square.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Walter Soyka
    December 5, 2011 at 3:31 am
    Make sure the Pixel Aspect Ratio Correction toggle is enabled. It’s below the viewer and looks like this: [image].
    The image in the viewer may look a little jagged with PAR correction enabled, but your renders will be perfect.
    Walter Soyka
  • Anilio Sweet
    December 5, 2011 at 8:28 am
    Yes thank you ive got it it worked
  • Anilio Sweet
    December 5, 2011 at 8:29 am
    Hi Ted.
    It was also like you said. it want scuare in comp, i checked the scuar button in de compsettings and it change correctly…
    thank you
