Activity › Forums › Adobe Photoshop › How come I can’t save as a jpeg?
Posted by Josh J. johnson on August 6, 2007 at 3:06 pmWhen I go to save as jpeg isn’t listed in the pull down? what am I doing wrong do I have to download a plug in?
thanks
Cora Smith replied 10 years, 10 months ago 8 Members · 7 Replies -
Markofcain
August 7, 2007 at 2:52 amWhat are your options?
It could be possible that you have a setting on the image that restricts the number of options for saving the file e.g. the mode of the image. What is the mode setting? Perhaps it is still possible to use File –> Save for Web…
HTH,
Mark Cain
Sarasota, FL USA -
Dutchm913
August 11, 2007 at 1:27 amif your trying to save a GIF file as jpeg it won’t let you,, simply open image ready with the same pic then save as jpeg ..or open with piant and save as jpeg
Abraham Chaffin
August 15, 2007 at 5:34 pmAnother way to save a gif as a jpeg is change the mode to RGB instead of indexed color. Image Menu > Mode
Ben Armitage
January 23, 2011 at 9:57 pmHi mate
Listen you dont need to download any plugins
I had this problem aswell when i started out……..
If your saving files in either RGB or CYMK anything more than
8 bits/Channel wont let you save as a JPEG file…..
so theres your answer, go to
IMAGE-MODE- and just make sure the 8 bits/channel is tickedHope This helps you
Jen Dorman
February 23, 2012 at 6:05 pmI am saving a jpg for web & devices and then when I go to name it and save it where I can use it, there is no save button.
May Tulin
August 9, 2013 at 12:48 amOMg thank you, I just had the same problem, it was this detail!!!
