Activity Forums Adobe After Effects How come a luma matte can give you one effect in one composition and a completely different one in another?
  • How come a luma matte can give you one effect in one composition and a completely different one in another?
    Posted by Daniel Haskett on May 27, 2005 at 12:01 am
    hi there
    Basically Ive been having problems using luma mattes. In one composition when I use it, it eliminates most of the white allowing any layers beneath to show thru, but in another composition it makes everytihng in the layer below inverted and horrible, I just dont understand what im doing wrong. Is it soemthing in composition settings because I cant find anything?! I just dont understand 🙁
    thanks in advance
    dan
    Filip Vandueren replied 21 years, 3 months ago 5 Members · 9 Replies
  • 9 Replies
  • John Dickinson
    May 27, 2005 at 12:53 am
    sounds like you may be applying it incorrectly… can you email me the project?
    john.dickinson@foxtel.com.au
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Daniel Haskett
    May 27, 2005 at 1:01 am
    Hi there
    Well basically, I really dont know whats wrong. Ive actually imported a composition where I know the luma matte works fine, then copied and pasted the two layers into a new composition and the same still happens! It makes absolutely no sense at all. Its like in one composition they are fine and in the other comlpetley the opposite. I can email the project but i have a feeling itd be massive casue of the size of the video….?
    cheers
    dan
  • John Dickinson
    May 27, 2005 at 1:05 am
    Can you take a screen shot of the one that’s not working and let us see it?
    John Dickinson
    Motionworks
  • Daniel Haskett
    May 27, 2005 at 2:28 am
    hey man
    sorry for the delayed response
    here is the screenshot https://rapidshare.de/files/2003842/luma-matte.jpg.html
    scroll down to bottom and press FREE to view it.
    thanks
    dan
  • John Dickinson
    May 27, 2005 at 4:00 am
    Sorry Daniel but it’s still not clear to me from this shot. Maybe someone else here can help?
    John Dickinson
    Motionworks
  • Chris Smith
    May 27, 2005 at 4:46 am
    It looks like it is being used correctly but I’d be curious to see the files by themselves. Are you sure you’re not selecting Luma inverted? As opposed to luma?
    Chris Smith
    https://www.sugarfilmproduction.com
  • Daniel Haskett
    May 27, 2005 at 11:07 am
    Ive tried all the different alpha/luma modes and it none of them work 🙁 I found a really really long winded way where I import a project that has successful luma mattes in and then copy the compositions into my current project and use them, but its just so bizarre. Theres not really anyway I can send the files I would have thought they are too big 🙁
    Thanks for your help tho!
    Dan
  • Jim Tierney
    May 28, 2005 at 1:33 am
    In the Composition that does work are there any other layers? Is it possible other layers may be affecting the two that you’ve shown us?
    Also, check that the imported footage is interpreted correctly. Perhaps when you import it into the new project, it’s being imported with an alpha channel or some other setting switched on or off.
    cheers,
    Jim
    Jim Tierney
    Digital Anarchy
    http://www.digitalanarchy.com
    415-586-8434
  • Filip Vandueren
    May 29, 2005 at 11:02 pm
    What’s the background color of the comp,
    what’s the effect you want
    Are there any filters on there, or masks ?
