Activity Forums Adobe After Effects How can you setup your particles to get this kkind of sliding effect?
  • How can you setup your particles to get this kkind of sliding effect?
    Posted by Syed Iqbal on March 11, 2020 at 8:40 pm
    I am inspired by this motion background and want to know the technique behind this particle sliding effect. I have checked various settings in Particular but as of now, I am not being able to figure it out.
    Here is the clip that I like to recreate:
    https://videohive.net/item/sliding-particles/25856031
    One thing I could think of was to use a light on a motion path but then it would only create one streak of particles sliding on a path using a light source as its path, whereas in the example video these are probably several dozens of streaks from left to right.
    Syed
    Graham Quince replied 6 years, 6 months ago 2 Members · 1 Reply
  • Graham Quince
    March 14, 2020 at 4:38 pm
    It’s been a little while since I played with motion paths, but I don’t think it forces every particle down a single set of coordinates, I’m fairly certain each particle will follow its own motion path based on its origin point.
    Have you tried a really wide emitter and one motion path?
    http://www.YouTube.com/ShiveringCactus – Free FX for amateur films
    https://shiveringcactus.wordpress.com/ – FX blog
