Activity Forums DaVinci Resolve How can you reconform correct grade VERSIONS?
  • How can you reconform correct grade VERSIONS?
    Posted by Toby Tomkins on March 4, 2012 at 2:05 pm
    Is there a way to use ColorTrace (or XML import to an existing session) to not only copy over the grades, but have the correct/current VERSIONS of a grade copied over to a new edit??
    I.e. how can I migrate grades from cut1 to cut2 and have the version activated in cut1, activated in cut2.
    Toby
    Toby Tomkins replied 14 years, 5 months ago 5 Members · 7 Replies
  • 7 Replies
  • Gabriele Turchi
    March 4, 2012 at 4:38 pm
    it’s not possible as far as today ..
    i wish that creating session with handles or importing new XML (that have a bit of slip here and there ) would import the versions currently in use in the master session ..
    g
    Davinci Resolve Control Surface
    MacPro
    Cubix desktop 4
    2 Red Rockets
    GTX470+GTX470+GTX285
    24GB RAM
    HP Dreamcolor
    Panasonic 58PF Plasma
  • Chris Hall
    March 5, 2012 at 4:58 pm
    Concur whole-heartedly on this. Its causing me a lot of wasted time in sessions with clients asking why all our previous work isn’t showing up when we reconform or add in new clips etc. (of course everything is there, it just has to be manually selected… not so fun). Can lead to some very nerve-racking “QC” sessions if there’s last minute changes…
    Chris Hall
    Colorist – Basher Films
    Pasadena, CA
  • Joseph Owens
    March 5, 2012 at 7:36 pm
    Yeah, its not exactly the same as “Reconform” was in COLOR, is it, where all 4 “hot” grades would get re-attached. My pet peeve is the addition of phantom dynamics that may correspond to a changed handle, or in point, or not.
    jPo
    You mean “Old Ben”? Ben Kenobi?
  • Michael Stirling
    April 3, 2012 at 12:22 pm
    Arrgh!
    I was just about to ask this very question. I have a reconform of a feature to do and this means Da Vinci Resolve doesn’t do reconforms.
    So this is the workflow:
    click conform page
    load old reel
    click color page
    find clip
    note version
    click conform page
    load new reel
    click color page
    find clip
    check version
    repeat 1500 times
    Anyone have a workround that’s even a click per cycle quickly please tell me and i might get to see my family by Easter
    ~M
  • Toby Tomkins
    April 3, 2012 at 12:39 pm
    I’m about to do you a big favour and save you a lot of time (-: so next time you’re in Soho, London, buy me a pint (-;
    What I worked out you can do recently is: duplicate the old project, and in the color tab, click on the timeline and select Batch Copy. This will un-connect clips of the same take but create master versions of the grade you had for each clip (but you can later create groups of these if necessary, which I think is much less time intensive than your method). You can then import the new XML and everything should match up with the correct versions and I believe the other versions are still there. It’s been a couple weeks but I think this is the method (it definitely involves batch copy). Duplicate projects before doing anything! (right click on a project/session and click save as to duplicate.
    Let us know the exact method if you work it out! It was a lifesaver on ‘Ill Manors’, Plan-B’s debut feature film that I’ve just finished! (-:
    Good luck!
  • Michael Stirling
    April 3, 2012 at 3:06 pm
    Thank you Toby
    The drinks are definitely on me!
    It works a treat and is actually more effective than you said because all the source clip links remain
    Workflow:
    Session A (old conform)- batch copy
    Session B (reconform) – batch unlink, batch link
    err, that’s it (you can batch link session A if you like to it’s back to ‘normal’)
    We should have a London Colourists social and I could buy yu that pint. In the meantime I’m going to bump this solution to the top
    Michael
  • Toby Tomkins
    April 3, 2012 at 3:41 pm
    Oh yeah! Dont think I tried batch link. Double check the right versions are active though, not just the version number from the 1st use of the clip etc.
    A London colourist social would be great, but it would have to around 10pm lol
    Failing that drop me an email next time you’re near Goodge St and I’ll collect on that pint!
