Activity › Forums › Adobe After Effects › How can you get a motion blur when panning with 3d camera?
  • How can you get a motion blur when panning with 3d camera?
    Posted by Daniel Haskett on November 21, 2007 at 3:56 pm
    Hi there
    Basically ive got 2 comps, lined up next to each other and i quickly pan from one to the next, but how can i get it so there is a bit of a blur between the two? whats the best way to do it. ive done a search but couldnt find much….saw something about ramping up the frame rate and then using motion blur….how do i do this?
    its 1 comp….with 2 comps in and a 3d camera.
    thanks in advance!
    dan
    Bart Straman replied 18 years, 10 months ago 4 Members · 4 Replies
  • Steve Roberts
    November 21, 2007 at 4:01 pm
    Did you switch on motion blur for both comp layers, and at the top of the main timeline?
  • Darby Edelen
    November 21, 2007 at 4:34 pm
    To increase the blur in a composition (this is assuming you have it on already) you need to go to composition settings (cmd+k/ctrl+k) and change the shutter angle. Higher shutter angle = more blur. If you have CS3 then you might also want to increase the number of samples for blurring 3D layers more naturally (with high motion/shutter angles you can sometimes make out the individual samples in the blur).
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Daniel Haskett
    November 21, 2007 at 11:54 pm
    cheers guys thanks for your help it’s much appreciated!
    dan
  • Bart Straman
    November 22, 2007 at 7:39 am
    heey
    mayby a force motion blur will work as wel.
    Bart
