Activity › Forums › Adobe Illustrator › How can you create a dashed line like for a MAP journey?
  • How can you create a dashed line like for a MAP journey?
    Posted by Daniel Haskett on October 18, 2006 at 11:51 am
    Hi there
    Basically i want to show a journey across a map and was just wondering the best way to do this in photoshop, id preferably like a clean dashed line….if that makes sense?
    Thanks in advance!
    Dan
    Jimmy Brunger replied 19 years, 11 months ago 4 Members · 3 Replies
  • Del Holford
    October 19, 2006 at 8:07 pm
    Hi
    While tedious, an individual segment of the line per layer would get you what you want. That would be a lot of layers. Start with the final line and reduce it by one dash, save file, then remove another segment of the dash, save file, etc. until you’re down to only one dash. Put the layers back together with 1+2+3+4…until the map is redrawn with all the segments revealed.
    I think creating an Action would reduce the time to create and save the layers as files.
    This is a crude and elementary way to do the animation but it would work and you could use blending options to enhance the look of the dashed line.
    Del
    fire*, smoke*, photoshopCS2
    Charlotte Public Television
  • Michael Ebert
    October 21, 2006 at 9:44 pm
    You could also use a mask in your video editing program… You would create the complete dashed line in Photoshop, and then “reveal” it cumulatively by moving the mask over time in Premiere, for example…
    –Michael.
    // love what you do or do something else. //
    Michael Ebert — graphic designer, jazz saxophonist, horror movie devotee
    https://homepage.mac.com/mwebert
    mwebert@mac.com
  • Jimmy Brunger
    October 30, 2006 at 11:46 am
    Or create path in Illustrator (or PS then copy/paste or save path to Illust) then stroke the path in Illustrator as a dashed line, then either save AI file for placement back in PS or just copy as paste as smart object direct.
    I’m amazed there isn’t a dashed line option in PS (or is there?) but this workaround is pretty quick.
    *Production Studio Premium – *Combustion 3
    Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / BMD DeckLink Pro / Sony BVM-20G1E / DVS SDI Clipstation
