Activity Forums Adobe After Effects How can you add a heat wave to a precomp and mask it out?
  • How can you add a heat wave to a precomp and mask it out?
    Posted by Daniel Haskett on November 18, 2007 at 3:22 pm
    Hi there,
    Ok so ive got a precomp of a scene with stuff popping up in the foreground. i want there to be a heatwave and im using cc particle world to create the displacement map and then using compound blur. it works nicely, however i dont want it to manipulate stuff in the foreground popping up, they need to be crisp….
    soo i tried to add a mask to the displacement map (which is a pre comp), but it doesnt seem to be recognised. i then tried to add a mask within the precomp on the cc particle layers but they dont accept the mask it would seem.
    soo…can anyone recommend the best way of doing it? i know i could add the heatve to each individual layer, but theres a lot of them and im sure theres a better way than that.
    cheers
    dan
    Darby Edelen replied 18 years, 8 months ago 3 Members · 2 Replies
  • Torbjørn Ljunggren
    November 18, 2007 at 6:08 pm
    dunno if i get your problem right.
    can you not simply put the crisp stuff in the foreground?
    if not. can you use track matte? put your crisp stuff in a separate comp & use this as the matte for the heatwave-precomp?
  • Darby Edelen
    November 18, 2007 at 7:03 pm
    Why don’t you only apply the distortion/blur to the background layers using an adjustment layer or use two separate pre-comps (a foreground pre-comp and a background pre-comp, apply the distortion to the background pre-comp)?
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
