Activity › Forums › Boris FX Particle Illusion › How can this be done?
Posted by Dotan Baytman on September 9, 2006 at 5:00 pmCan i create this effects like fire/water using PI3?
https://www.jcspost.co.il/download/animations_files/13406.wmv
thanxBjohnston replied 20 years ago 3 Members · 3 Replies -
Alan Lorence
September 10, 2006 at 2:25 pmSomething similar, but not exact. The fire is the easy part, but the water may be impossible. The reason is, in that clip the water is “smooth”, and you can see the person behind the water. pIllusion doesn’t do “smooth” water very well, as that’s a job for a fluid simulation/renderer, not a sprite-based particle system.
For the fire, you also won’t get as much 3D to it, but you can do it by animating the “zoom” property.
Alan.
wondertouch -
Dotan Baytman
September 10, 2006 at 3:37 pmThanx alan
so what did they use to do that?
3D application?
