Activity Forums Adobe Photoshop How can I use the Alpha Channel to make a mask?
  • How can I use the Alpha Channel to make a mask?
    Posted by Milton Hockman on March 21, 2006 at 3:02 pm
    I am on PS 6.0
    I have a picture of a man in a background
    I want to cut him out of the background
    I do not want to delete the background that I cut out.
    I just want to mask it so if later i want to bring part of it back i can.
    I know i can create a mask on the layer and use the brush tool to paint out what I don’t want. But when i paint back on the background I have to guess where the edge of the man is.
    I thought there was a way to paint on the alpha channel itself to achieve this effect. A way that would show me Red where the mask is hiding what I don’t want to see.
    Then if i wanted to touch up the edge of the man, i could see through the Red to know where to paint.
    anyone know how to do this?
    Richard Harrington replied 20 years, 5 months ago 3 Members · 2 Replies
  • Isotrope
    March 24, 2006 at 8:58 pm
    Hi mr_gfx,
    since I’m not certain how you’re set-up is, I would suggest that you make a quick selection (Lasso, Ellipse, Rectangle,…) of a part that you want to keep.
    Now, press Q. You have just activated the QuickMask tool. Is the part you selected red? or is it the opposite?
    I find that some jobs are easier to work on with the Red on the outside, others with the Red on the inside. To revert to normal mode, just hit Q again.
    But how do I switch it? you might ask. Look at your main toolbar, right below the Front/Background letter, you’ll find it to the right (I am looking at CS2 but it is quite similar in 6, if I recall correctly). When you find the icon, double-click it. The options will appear. You can even change the Red to something else.
    Hope this helps,
    iso
  • Richard Harrington
    March 26, 2006 at 3:05 am
    Quick mask cannot be saved with document…
    Be sure to create a new channel in the channels palette (that’ll be the alpha)
