Activity › Forums › Adobe After Effects › How can i use parent , but only for position (without rotation)?
  • How can i use parent , but only for position (without rotation)?
    Posted by Hanj Baba on August 7, 2007 at 1:46 am
    Hello,
    I created a “marionette” – photoshop comp’ of a man with layer for every part of the body.
    I made a simple animation – walking…
    the problem is tht I want to attach “strings” (a simple stroke) to some of the layers, so it woud look like a marionette.
    is there a simple way to do this ?
    thanks
    Michael Duff replied 19 years, 1 month ago 2 Members · 1 Reply
  • Michael Duff
    August 7, 2007 at 6:20 am
    ” How can i use parent , but only for position (without rotation)?”
    you need to use expressions … but luckily you don’t actually need to write any .. you can use the pick whip …. select both layers and hit “p” to show position … on the one that will be the “child” alt click on the keyframe button to enable expression … then using the pick whip (the little spiral button) drag it to position on the parent layer. . . done!
