How can I use a Null path for text?
I’m stuck! I have already set up a particular effect following a null path in 3D space. I have decided that I now want a word to follow that same path shape bending along its curves, but of course Text only seems to want to follow a Mask path. I don’t want to make a Mask path and try to line it up with the existing Null path. So, is it possible to convert the Null path with its Bezier curves into a Mask path? Or can you suggest another way to do this to achieve a precision line up.
Of course, I don’t want to start from scratch by the way!
Thanks. Mark
