Activity › Forums › Adobe After Effects › How can I translate width and height resolution to dimensions (11 x 17)?
  • How can I translate width and height resolution to dimensions (11 x 17)?
    Posted by Hilary Tsai on October 28, 2020 at 4:47 pm
    I’m doing a poster design, and one of the specs is 11 width by 17 height (no unit measurement given). Is there a way within AE to translate between resolution and dimension? I could do it manually, but wondered if there is a way.
    Walter Soyka replied 5 years, 11 months ago 2 Members · 1 Reply
  • Walter Soyka
    October 28, 2020 at 4:58 pm
    Ae only thinks in pixels; if you’re using it for print, you have to do the math yourself.
    Assuming this is 11in x 17in, and assuming a quarter inch of bleed all around, and assuming 300 dpi, that works out like this:
    11.5in * 300dpi x 17.5in * 300dpi = 3450px x 5250px
    (Of course, you’ll need to confirm units, bleed and print resolution to calculate the final pixel dimensions correctly.)
