Activity Forums Adobe After Effects How can i swich off the lines in the flare effect?
  • How can i swich off the lines in the flare effect?
    Posted by Daniel Nedelchev on May 18, 2009 at 9:43 am
    Hi all. I have a problem whit AE and i really need some help. Pls, look at the attached screen shoot and tell me how can i make the lines in the effects dissapear – they apper in the rendered movie also, and i don’t know how to switch them off.
    Thanks in advance
    Joey Burnham replied 17 years, 3 months ago 3 Members · 2 Replies
  • Kevin Camp
    May 18, 2009 at 3:03 pm
    that’s normally the mark for an unregistered third-party effect/plugin. to get rid of it you’ll need to register it.
    if you’ve already paid for it, you should have a registration number and instruction on how to enter it. if you don’t have the number, try contacting the company’s support to get it re-sent to you, or to find out how to register their software… each company is a little different.
    if you haven’t paid for it, then you’ll need to to remove the watermark.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Joey Burnham
    May 18, 2009 at 6:06 pm
    looks like you downloaded a template right?
    If so check with the website to see what plugins are necessary to make it work. a lot of the time they will get you fully rendered efx that require plug-ins so that you don’t need to have the plugins to make the templates work. if you didn’t read the fine print and it says that you HAVE to have the plugin first before you can use the template then you are kinda screwed.
