Activity › Forums › Adobe After Effects › How can I simulate a heart monitor?
Posted by Kevin Walters on June 3, 2008 at 7:01 pmI am in need of knowing how to make a heart monitor in after effects. I have AF 5.0 (old, I know) is there anyway of doing that. it is needed for a Television bumper…
Craig Davis replied 18 years, 4 months ago 5 Members · 5 Replies -
Tl Westgate
June 3, 2008 at 8:23 pmIt’s hidden in the tutorials section under the cryptic headline of “Creating a Heart Monitor.”
https://library.creativecow.net/articles/rabinowitz_aharon/CC_Heart_Monitor.php
— TL
Kevin Camp
June 3, 2008 at 8:36 pman easy way is to google image search for ‘ekg’ find an image that will work for, then take that into ae, and redraw it with a ‘mask’ using the pen tool. once your vector path is drawn, use 3d stroke (from trapcode.com) to animate a stroke over the path. then maybe add some glow to add to the effect.
if you don’t have 3d stroke, you could use stroke, but then you’d probably need to animate a linear wipe effect or two to make it seem like it draws on and fades out as it draws. at that point you may just be able to create a matte from the image you found on line and wipe that on and off to create the animation.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Ron Coy
June 4, 2008 at 4:20 amI did one for a client using 3D Stroke and Shine. It’s on my demo page at https://www.roncoy.com/Demo.html
Craig Davis
June 4, 2008 at 1:52 pmif you dont have 3d stroke, i would suggest creating some graphics (your heart beat line) in Photoshop or Illustrator and animating masks on that graphic in AE. You might also make the graphics in AE if it works for you. Add a little feather to your mask and animate it across your graphic. i hope that helps a bit. lets go Wings!
Craig Davis
Color Bars Communications, Inc.
http://www.colorbarsvideo.com
