Activity Forums Adobe After Effects how can I sharpen through an alpha channel like in Photoshop?
  • how can I sharpen through an alpha channel like in Photoshop?
    Posted by Jon Iverson on April 25, 2013 at 12:55 pm
    I’m simply trying to emulate the routine discussed here and apply in AE CS4. Can someone please direct me to a tutorial/ instructions? Thank you.
    Darby Edelen replied 13 years, 4 months ago 4 Members · 5 Replies
  • Tudor “ted” jelescu
    April 25, 2013 at 1:04 pm
    One way of doing it:
    You can duplicate your layer, apply find edges and precomp. Use this as a Track Matte for a Adjustment layer that you create on top of the bottom video layer. Apply Sharpen on the Adjustment layer.
    I am not sure though that this will give you better results than just applying Sharpen directly to the video layer.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Walter Soyka
    April 25, 2013 at 8:14 pm
    You might like Darby Edelen’s excellent technique for high pass in Ae:
    https://forums.creativecow.net/readpost/2/931967
    Walter Soyka
  • Darby Edelen
    April 26, 2013 at 12:08 am
    [Walter Soyka] “You might like Darby Edelen’s excellent technique for high pass in Ae:”
    I’ve changed my wicked ways 🙂 I usually just use Unsharp Mask now since it’s virtually the same result but faster to apply.
    You can apply Stylize > Find Edges to a copy of your footage and use this as a luma matte for another copy of your footage with Unsharp Mask applied to follow along with the tutorial you linked to (applying the appropriate blurs and levels adjustments).
    However, I’d just apply Unsharp Mask and use the Threshold parameter to reduce the sharpening in lower contrast areas (basically what the Find Edges operation would do).
    Again, if you want to follow the tutorial directly you’d set the Unsharp Mask copy of your footage to the Lighten blend mode.
    Darby Edelen
  • Jon Iverson
    April 26, 2013 at 11:48 am
    Problem solved. Created an action in Photoshop to do what I wanted to, then used Virtual Dub to convert the video to an image sequence, allowed PS to do the custom sharpening, and then Virtual Dub to reassemble the images back into the video.
  • Darby Edelen
    April 27, 2013 at 2:35 am
    [Jon Iverson] “Problem solved. Created an action in Photoshop to do what I wanted to, then used Virtual Dub to convert the video to an image sequence, allowed PS to do the custom sharpening, and then Virtual Dub to reassemble the images back into the video.”
    Alrighty, but you could’ve done everything that’s in that tutorial directly inside of After Effects. It’d render faster and be much more straight forward as well.
    Darby Edelen
