Activity › Forums › Zaxwerks › How can I set underlying transparency in invigorator
  • How can I set underlying transparency in invigorator
    Posted by Mark Cookman on March 3, 2010 at 5:43 pm
    4.3.0
    I have a layer mapped material that gradually introduces transparent areas – as these appear the underlying (default) surface colour of my object is revealed – how can I obtain a transparent default colour?
    Edward Wu replied 16 years, 7 months ago 2 Members · 3 Replies
  • Edward Wu
    March 3, 2010 at 6:50 pm
    Hi Mark,
    I’m not quite sure what you meant by a transparent default color. Can you elaborate a little more on that?
    In general, if you want a material swatch to be transparent, you can adjust the “Transparency” setting, and your material will become transparent. If you’re working with a layer map, it can be a pre-comp where you animate the alpha channel. Then the transparency area for your object can move to introduce different areas like you mentioned.
    Best,
    Edward
  • Mark Cookman
    March 4, 2010 at 4:43 pm
    By default colour I mean what Zax refers to as underlying surface colour.
    For any folks trying to make parts of their objects transparent: – you need to assign alpha information to the texture map thumbnail position next to transparency; ie. second slot from bottom.
  • Edward Wu
    March 4, 2010 at 6:02 pm
    Hi Mark,
    The surface color transparency is controlled by the Transparency setting. If you adjust the transparency, your material will become transparent. However, if you have a Transparency map applied, the transparency will only be applied to the areas that are non-white on your transparency map. This means that areas that are white will still be opaque while gray/black areas will become transparent.
    Best,
    Edward
