Activity › Forums › VEGAS Pro › How can I remove all images from a shot except for anything with a specific color?
  • How can I remove all images from a shot except for anything with a specific color?
    Posted by Angelo Mike on September 25, 2013 at 5:54 pm
    I’m trying to isolate a red in a shot, but not to make everything else black and white. I want to basically do a reverse key out if possible. Select the red (animated text, in this case), and remove everything else from the show. I can key out each other color from the shot with Vegas, but it’s too messy. It just doesn’t work and there’s no point on the high and low threshold that will key everything else out and keep the red. Or I have to reduce the key out so much that the other colors are in there.
    I did a mask over each individual letter, but you still see the black and white of the letters before the text animates.
    Is there any way to do this?
    The Secondary Color Corrector doesn’t quite work, either. The text is animated as if you are seeing it being handwritten on screen, so instead what you see is the finished text at the end when you use this with the Select Effect Range tool. I could keyframe a pan across the screen, but it’s not the same as seeing the writing fill in as if written by hand.
    Angelo Mike replied 13 years ago 3 Members · 12 Replies
  • 12 Replies
  • Graham Bernard
    September 25, 2013 at 7:52 pm
    Do you want the the non-RED items removed, leaving WHITE or TRANSPARENT?
    Could you post a “still” with which to experiment?
    Grazie
  • Angelo Mike
    September 25, 2013 at 7:56 pm
    Exactly, I want them removed so that everything else in the shot is gone. White or transparent both work fine.
    I ended up just faking it by using the Secondary Color Corrector and panning across the letters, but I still want to know how to do this.
  • Graham Bernard
    September 25, 2013 at 7:57 pm
    As per my edited post above – A “still” would be neat to have?
    G
  • Angelo Mike
    September 25, 2013 at 9:29 pm
    [Graham Bernard] “As per my edited post above – A “still” would be neat to have?”
    I’m not quite sure what you’re asking. It’s got to show the text looking like it’s being hand drawn on screen.
  • Stephen Mann
    September 25, 2013 at 10:34 pm
    Like Graham, I’m not following what you are trying to do in the end. Can you post an example?
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Angelo Mike
    September 25, 2013 at 10:43 pm
    Well, here’s the original that I tried to extract the written text from. I still don’t know how to link stuff, so you may have to copy and paste this into your browser.
    https://youtu.be/MAU_Ez84l4c?t=1m18s
    And here’s the finished video I did. I ended up using Secondary Color Corrector, drew a mask around each individual letter, selected red, and used pan and crop to go from left to right. But it’s still not quite what I was trying to do.
    https://youtu.be/uAwEfJYT1nA?t=2m17s
    You can tell it’s not quite what the original was as a result.
  • Stephen Mann
    September 26, 2013 at 3:54 am
    Your links don’t go anywhere.
    You can either highlight the link and click on the blue “L” icon above, or click on the camera icon and upload the video.
    Steve Mann
    http://www.mmdv.com
  • Angelo Mike
    September 26, 2013 at 3:59 am
    Did you try copying and pasting them? They work for me.
    Here are direct links of the video I took the text from (jump to the last 10 seconds for the text):
    And the video I made, which I used a sort of back door method to simulate what the original had, though it obviously doesn’t look quite the same (again, jump to the last 10 seconds).
  • Graham Bernard
    September 26, 2013 at 4:58 am
    Angelo? I have to ask, is this your original work that you are adapting? Or is it owned by somebody else and you are adapting for your own usage? If it is the latter then I’d start-over and do my own “words” and use what appears to be a sweep-reveal. It’s not “written”! But again, you need to aware of any further “rights” to that usage of the tag-line and if that is a copyright-ed logo. I’m just saying this so you can be made aware of the issues that could ensue – yes?
    Notwithstanding your response to my first comments on “ownership”, and speaking in generalities, I’d try:-
    A] Maybe a Difference Background treatment. If you have a Black and White without the writing then that would be a way to go forward.
    or…
    B] Using the Channel Blend to move as much of the Red Channel pixels into the Alpha Channel and alter the Blue channel – a lot of “blue” hides in the blue channel . . oh yes . . !
    or…
    C] Start-over and do your own graphic. It’s dead easy and most like will give you the least grief.
    Grazie
  • Angelo Mike
    September 26, 2013 at 5:04 am
    I might try those should I ever do it in the future.
