Activity Forums Adobe After Effects How can I re-use an animating in a similar way to a Photoshop Smart Layer?
  • How can I re-use an animating in a similar way to a Photoshop Smart Layer?
    Posted by Robert Maric on March 30, 2017 at 1:23 am
    Hi there,
    If I create a small animation, let’s say the letter A spinning inside a vector circle, is there a way to wrap that up as a single object I can multiply on the stage as many times as I want (have 10 of them in a grid)? I know I could precompose but then I would lose the ability to scale or 3d rotate the animation from the parent comp.
    I would definitely want to be able to edit the animation just once and have that change reflected in every instance of it
    Cheers
    Kevin Camp replied 9 years, 5 months ago 2 Members · 1 Reply
  • Kevin Camp
    March 30, 2017 at 7:00 pm
    [Robert Maric] “I know I could precompose but then I would lose the ability to scale or 3d rotate the animation from the parent comp.”
    if you click the ‘continuously rasterize/collapse transformations’ switch for that pre-comp layer, you should be able to scale or 3d rotate the pre-comp within the main comp. it’s the switch that looks like a little sun or spikes ball in the timeline (when switches are visible).
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
