Activity Forums Adobe After Effects How can I preview a piece my clip with the audio
  • How can I preview a piece my clip with the audio
    Posted by Shahin Sanayei on December 13, 2010 at 5:20 pm
    Ok I know how to preview my WHOLE clip including my audio, it’s with the 0 key on the num pad.
    But what if I want to just preview a few seconds of my clip to see if a specific action or a move etc. matches my audio on that frame??
    How can I avoid RAM previewing (including audio) the whole clip to save time???
    At the moment I use the 0 num pad key to render the whole clip to preview the few seconds in the middle of the clip that I need to check if that part goes together with the audio and that takes a long time…
    Thank you!
    Shahin
    Shahin Sanayei replied 15 years, 8 months ago 2 Members · 2 Replies
  • Kylee Pena
    December 13, 2010 at 8:58 pm
    You can also scrub the audio with command+option+drag time indicator (audio and video at the same time with command + drag time indicator). Sometimes that might serve your previewing purposes.
  • Shahin Sanayei
    December 14, 2010 at 5:02 am
    Thank you, I will read through it and try that!
    Shahin
