Activity Forums Adobe After Effects How can I mask this image on better so it looks more NATURAL?
  • How can I mask this image on better so it looks more NATURAL?
    Posted by Daniel Haskett on May 25, 2006 at 7:26 pm
    Hi there
    Basically Ive got an animation that im trying to do of a sky scribbling on to the screen and then mountains appearing underneath….this is a very rough idea of what i mean https://www.danhaskett.co.uk/early%20test.mov
    Basically I want the lines of the sky to look they are being scribbled on, drawn on, but at the moment using the stroke effect it just looks lame. I dont know how to even get a brush that works better…isnt there a way I can use the paint effect to mask it on cause ive got a wacom tablet to use.
    Then with the mountains are there any tips on how to make the snow and textures appear more naturally? The best example that I can think of is in this music video https://www.youtube.com/watch?v=JgKUnhCANTY
    The way they mask it on there looks so good….any ideas on how to do similar effects, or say having the snow kind of melt down the mountains….a bit like when you see paint dripping down revealing stuff.
    Any help would be greatly appreciated!
    Oh and ive got AE7 if that makes any difference,
    Dan
    Mike Smith replied 20 years, 3 months ago 5 Members · 9 Replies
  • 9 Replies
  • Barend Onneweer
    May 25, 2006 at 9:04 pm
    Have a look at the scribbler plug-in that comes with AE. (I think that’s what it’s called, not near my workstation right now).
    It’ll create the scribbly line and you can animate it to appear.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Justin Productions
    May 25, 2006 at 9:05 pm
    Well, I did not watch your videos (I have Quicktime 6.0) but for the pen thing, you could go here, on Mylenium’s website 🙂
    Maybe that will help. If yes, don’t thank me, thank Mylenium 🙂
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.0 Professional
  • Daniel Haskett
    May 25, 2006 at 9:47 pm
    Thanks guys am gonna give it a go now!
    Dan
  • Mike.holmes
    May 26, 2006 at 2:51 am
    it looks like they used a ‘Trapcode’ plug-in ‘particular’ i’m only just learning myself so the way i’d do it would be to create a mask and use particular to fill up the space??? if that makes sence?? the plug in can be purchased at http://www.trapecode.com and the company who did the video is http://www.blind.com that should lead you in the right direction.
  • Mike Smith
    May 26, 2006 at 8:24 am
    For the future, you might want to take a look at the animation effects available with Painter …
  • Daniel Haskett
    May 27, 2006 at 9:36 pm
    Hey Mike
    Do you mean the program Painter? If so do you mean that you can use the brushes in it in conjunction with after effects. Or is Painter a plugin for after effects? Is it possible to bring in custom brushes into after effects?
    cheers
    dan
  • Mike Smith
    May 29, 2006 at 8:52 am
    The program Painter, yes. It’s a free-standing program, not any kind of plug-in, and sfaik there’s no way to use it inside AE. https://store.corel.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10102&mpe_id=11368&jspStoreDir=CorelUK&intv_id=13061&partNumber=OL_PF09&evtype=CpgnClick&langId=-11&catalogId=10805&ddkey=ClickInfo&trkid=ukgrgopa2
    BUT the brushes are fabulously powerful, there are superb liquid and distortion effects, and Painter has a couple of reaally good animation tools for short effects scenes.
    It allows for frame by frame animation with onion skinning and output to mov / avi files at whatever size / scale / compression the host system allows. So you can make effects you won’t often see anywhere else.
    And its scripting feature allows you to create a “painting” or graphic (using most of the Painter tools available, though you may have to be careful and what Paitner plug-ins you choose and use) and then “play back the whole creation process, ending up with the image creation as a recordable animation…
    Worth exploring the demo, if you have time to get used to the quirky interface and want to be able to make distinctive work.
  • Daniel Haskett
    May 29, 2006 at 9:28 pm
    Hey mike
    Thanks for the info, ive actually got painter, just not used it in a while. Having a play around now and its got some great brushes and features, but I have one question. When im creating an animation, i do make movie and say 24 frames with 2 layers of onion skin, which works fine when on the background layer, but as soon as you craete a new layer and start painting on that it goes weird. Basically all the brush strokes previous are left on the screen so you cant tell what the animation is gonna look like. But for some reason when you render it out it looks ok, but until then its hard to tell what itll look like…. Do you have any ideas?
    Cheers!
    Dan
  • Mike Smith
    May 30, 2006 at 2:20 pm
    Layer handling is very different in Painter, isn’t it. And with Painter movies how it works when you change from frame to frame seems to vary according to chosen brush, and its type of coverage.
    I haven’t worked out how to make it predictable (though I guess there must be a way!), and try to keep everything on one layer, or at worst flatten each frame to a single layer before leaving – not really too big a limitation.
    I find it sometimes helps to have an open, multiple layer image / composition to copy and paste out of, as a source to stick things into the frame stack.
