How can I make an effect follow a moving object while keeping the original
Hey everyone!
I’m working on a clip where I have a glow effect applied to a moving object, but I also need the glow to fade in and out at specific points in the clip. I can get the object tracked with motion tracking, but when I try to adjust the FX timing afterward, the keyframes and tracking data seem to interfere with each other.
Is there a good way in VEGAS Pro to have the effect follow the tracked object while still controlling when the effect itself appears/disappears? I’d rather not manually keyframe the whole thing if possible.
