Activity › Forums › Adobe Premiere Pro › how can i maintain quality of exported ae file when imported and put to timeline sequence in premier?
  • how can i maintain quality of exported ae file when imported and put to timeline sequence in premier?
    Posted by Arvin Marcial on February 9, 2012 at 9:24 am
    hi, i rendered a scene from after effects as quick time (.mov) file with 960×540 frame size and 30fps settings. then, i imported it to premier cs4. then i previewed it in the source monitor (monitor on the left) and it has the same good quality. then i dragged the file in my timeline that has a customized sequence settings of 960×540 frame size, square pixels and 30fps, but as i view it in my timeline monitor (monitor on the right), it has a bad quality going down like a stretched video. i even tried to export it in the same settings in the media encoder and still it was not like the one i rendered in after effects. can someone tell me wether its my premier sequence setting is wrong or maybe my i forget to set something on the playback and project settings?
    this is the preview in the source monitor (the one on the left side in premie)
    as you can see, it has the same good quality preview of the scene i rendered in after effects… but….
    when i dragged the source file in my time line, here’s what it looks like
    as you can see, the quality of the file i rendered in after effects dropped down some pixels as i go ahead with my project in my timeline. you can also see the difference by looking at the text below that gone down with blured pixels. it also adapt the bad quality as i render it out on media encoder.
    looking forward for someones help with my appreciation ..
    cheers from the far east Philippines
    Jon Barrie replied 14 years, 7 months ago 4 Members · 5 Replies
  • John Young
    February 9, 2012 at 3:09 pm
    Something is wrong with your Sequence Settings. You can see that they do not match your source footage (you’ve got black bars on the side of your program monitor).
    I would start with dragging the source clip in the Project window on to the “New Item” icon. (You can also right click and select “New Sequence From Clip”). This will create a sequence that matching the settings of your clip.
    John
  • Arvin Marcial
    February 9, 2012 at 5:23 pm
    Thank you very much for the reply sir john… but i couldn’t drag the file down to the “new item icon” in the project window. and also when i right click on it there wasn’t any “new sequence from the clip” option. maybe because i’m using cs4 version right? Thank very much
  • Arvin Marcial
    February 9, 2012 at 6:23 pm
  • Ann Bens
    February 9, 2012 at 8:28 pm
    There is no New Item icon in CS4. Thats a CS5(.5) feature.
    Make a new sequence by going into the General tab/editing mode/custom.
    Now you can set everything manually.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Jon Barrie
    February 10, 2012 at 2:51 am
    I have a sneaking suspicion that the custom sequence is set with a pixel aspect ratio of widescreen when it should be set to 1 square.
    JB
    Jon Barrie
    Adobe Video Solutions Consultant ANZ
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
