Activity › Forums › Apple Final Cut Pro Legacy › How can I keep the highest resolution in a 4×3 full screen project, originally shot in 16×9 HD?
  • How can I keep the highest resolution in a 4×3 full screen project, originally shot in 16×9 HD?
    Posted by Dave Chavinsky on March 3, 2012 at 11:44 pm
    I shoot my projects in HDV 1440×1080 (which.. I guess has rectangular pixels so its like 16×9? as I understand…), which I then use in an SD sequence that is full screen 4×3 in order to fit our projectors.
    Even though the highest resolution for out projectors is 480×640, I want to save my project for portfolio use in the highest resolution I can.
    Also.. I’m confused. I’m using a Sony Z1U. The ratio of 1440×1080 is a 4×3 ratio. Because of rectangular pixels it comes out as 16×9. So what is the ratio I should put on the sequence to make it 4×3 without losing any resolution? 1080 would stay the same.. what about width?
    David Roth weiss replied 14 years, 7 months ago 4 Members · 3 Replies
  • Michael Gissing
    March 4, 2012 at 12:40 am
    Lots of confusion over HDV, and using anamorphic to get a 16:9 image. In standard def non square pixels are the way to get a full height 16:9 image as SD frame sizes are 4:3.
    In HD 16:9 is the native format and is often acheived by using thin raster techniques like 1440 x 1080. Final Cut automatically handles this and produces a 16:9 image. In SD you have to tick the anamorphic button in the sequence settings to flag a 16:9 image and display it in FCP properly. In HD you do not tick the anamorphic box with HDV footage.
    To get a SD 4:3 image you should edit in HD, and then make your 4:3 SD file in Compressor by cropping the sides. You can reposition and even keyframe move the original to best frame for the crop. Use the guides in FCP and the 14:9 title safe marker is almost exactly the 4:3 crop point.
    In Compresssor the cropping settings are in the geometry tab and here you set both the crop, square pixels and the final frame size in SD you want. When you have set this go to the frame controls, turn them on and select resize best. This will give a better result that letting FCP rescale by dropping the final sequence into an SD timeline and rendering
  • Alexander Kallas
    March 6, 2012 at 4:42 am
    Great answer Michael !
    Cheers
    Alexander
  • David Roth weiss
    March 6, 2012 at 6:02 am
    [Michael Gissing] “In HD you do not tick the anamorphic box with HDV footage.
    In fact, you never tick the anamorphic box with any variety of HD footage. The anamorphic checkbox is strictly for widescreen SD codecs and widescreen SD sequences, and never HD of any flavor.
    Michael knows this, of course, I just wanted to emphasize that the rule is very much black and white, with no gray area to cause confusion.
    David Roth Weiss
    ProMax Systems
    Burbank
    DRW@ProMax.com
    http://www.ProMax.com
    Sales | Integration | Support
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
