Activity › Forums › Adobe Premiere Pro › How can i import mov footages with Avid DNxHD codec in premiere or after effect??
Ryan Constantino replied 11 years, 4 months ago 5 Members · 15 Replies
Arnaud Xetxu
September 4, 2013 at 11:52 amIts working on AE cs6 ( dont have Premiere Pro Cs6) but this is Still not working on Cs5… Do you have an idea ?!
Jeff Greenberg
September 4, 2013 at 1:52 pmIn AE click on the output module. Choose whatever is selected (lossless.)
Then Make sure QuickTime is the choice at the top.
Press format options.
Is DNxHD available in QuickTime?Here’s a quick set of screenshots:
https://imgur.com/a/41Xg5/embed -
Arnaud Xetxu
September 6, 2013 at 6:39 pmJust to let you know .. i took the decision to install the new CC version of premiere and ae. I will tell you if this working as soon as it is installed. I have another question for you.. promiss it will be the last one ! I did some 5DmkIII trials today shooting in H.264 and Dnxh HD via Hyperdeck shuttle 2. I was surprised cause the dnxhd images looked bader the h.264 : more noise, green color etc.. The DnxHD is supposed to have more color informations doesn’t it ? Thats why i don’t understand !
Thanks for your help again … -
Jeff Greenberg
September 6, 2013 at 7:48 pm[Arnaud Xetxu] “5DmkIII trials today shooting in H.264 and Dnxh HD via Hyperdeck shuttle 2. I was surprised cause the dnxhd images looked bader the h.264 : more noise, green color etc.. The DnxHD is supposed to have more color informations doesn’t it ? Thats why i don’t understand !
“Two things – first, you probably ought to start a separate thread for a separate problem.
Second, if you have something set incorrectly or you’re using the wrong DNxHD setting, you’re files will look bad.Best,
Jeff I. Greenberg
Author/Master Instructor/Speaker/Consulting
My contact info and more
New! Come see me speak @ NAB/Post Production World! -
Ryan Constantino
April 11, 2015 at 10:31 pmI know this is an old thread, but I figured out a work around, posting it here just in case someone else is searching.
I have a DNxHD .mov file that i needed to do some VFX to in after effects.
-File plays in VLC (maybe from perian install? Not sure)
-Doesn’t play in QT or Mpeg streamclip
-Can’t be imported into after effectsI downloaded the codec from Avid:
https://avid.force.com/pkb/articles/en_US/download/en423319-File now plays in QT and Mpeg streamclip.
-Still doesn’t import to After effects.Opened file in Mpeg streamclip, converted to prores4444
Did VFX in after effects with the prores file.
Not sure what else to do. Looking at the render queue I see that now I can export to DNxHD. wtf AE? You can export but not import DNxHD? You can be a fickle beast sometimes you know that? I’m Using CS5.5
