Activity › Forums › Adobe Premiere Pro › How can i import mov footages with Avid DNxHD codec in premiere or after effect??
Posted by Quokyung Tang on April 19, 2012 at 8:56 amHi all,
i have installed the codec package of “AvidCodecs LE 2.3.7” already.
I still cannot import it in premiere or after effect.
But i can play the footages on quicktime.
what is the problem??
Anyone can help??
I am using CS5 on window 7.Thanks!!
Ryan Constantino replied 11 years, 5 months ago 5 Members · 15 Replies -
Jeff Greenberg
May 20, 2012 at 2:31 pmIf qt sees it, AE or PP should see it. The files do have the extension, right?
Import the file into AE. Click on it. What does it say in about the file?
Best,
Jeff I. Greenberg
Editor/Author/Speaker/Consulting
My NAB seminar schedule, contact info and more -
Tom Hoopengardner
September 19, 2012 at 9:06 amSame problem. Black Magic Hyperdeck Studio generates MOV files using DNxHD codec. I need to edit the video using Premiere Pro CS5 / Windows Vista 64. The files play fine using QuickTime Player.
I downloaded from Avid and executed the file that’s supposed to install the codec. This seems to work fine.
When I try to import the files into Premiere, the error message is “Unsupported format or damaged file.”
I’ve also tried importing the files into After Effects. The error message is “File cannot be opened, it may be in an unsupported format.
I’ve combed through the Adobe and Avid forums. This seems to be a familiar problem. The suggestions either don’t work or are incomprehensible to me.
TomHoop
Arnaud Xetxu
September 3, 2013 at 4:35 pmHey,
Sorry to contact you again about this issue almost one year after the last post, but i just get the hyper deck shuttle 2. Its working with a canon 5d mk III. As you im getting DnxHD files and i cant import them in premiere pro CS5.5 even after the codec installation from Avid… Did you find a solution ? It will help me a lot ….
Thanks !
Jeff Greenberg
September 3, 2013 at 8:02 pmAre you sure you installed the extension correctly?
Best,
Jeff I. Greenberg
Author/Master Instructor/Speaker/Consulting
My contact info and more
New! Come see me speak @ NAB/Post Production World! -
Arnaud Xetxu
September 3, 2013 at 8:31 pmYes i did… Many Times !
I instalĺ and reinstall it .. I can export in dnx but when i try to put footages on the timeline it does not work. Also dnx does not appear in the preset when i creat a new séquence ! -
Jeff Greenberg
September 3, 2013 at 8:43 pmAmaud,
The presets only show up if you have QuickTime & DNxHD installed first.
First, lets see if it’s installed correctly:
Can you see DNxHD in QuickTime?Best,
Jeff I. Greenberg
Arnaud Xetxu
September 3, 2013 at 9:47 pmI can read dnx with QuickTime so yes i think this is installed well… Do you have an another way to check If this well installed ?
Jeff Greenberg
September 3, 2013 at 11:16 pmIf you have it installed, the next step is to see if it’s seen via QuickTime in Premiere Pro/ Adobe After Effects/ AME.
I have a prebuilt preset that builds a QuickTime DNxHD 145 (1080) item.
It’s here: https://www.dropbox.com/s/ezygn1ab0glc6u8/DNxHD%201080p24%20175%208%20bit%20RGB.epr.zipThis is for CS6 (or later.)
Best,
Jeff I. Greenberg
