Activity Forums VEGAS Pro How can I get the audio track to skooch and not snap?
  • How can I get the audio track to skooch and not snap?
    Posted by Norman Willis on August 25, 2010 at 7:24 pm
    New format, fresh install of Sony Vegas Pro 9.0e. I want to do two camera tracks and a Zoom H4N audio track with VASST InfinityCAM. Lining up the clapper board spikes in front was easy. I turned off Quantize to Frames, turned off Snap and just lined them up.
    On the back end, I went to skooch the H4N track up maybe a half a frame (just to make it right)…but it wants to jump the whole frame.
    I don’t get it. Quantize and Snap are off. What am doing wrong?
    Norman Willis
    http://www.nazareneisrael.org
    Norman Willis replied 16 years ago 3 Members · 7 Replies
  • 7 Replies
  • Jeff Schroeder
    August 25, 2010 at 9:23 pm
    Norman,
    Press the F8 key. It toggles ‘Enable Snapping’
    Jeff
    http://www.narrowroadmedia.com
  • Norman Willis
    August 26, 2010 at 1:26 am
    Right. Thanks. 🙂
    But it snaps a whole frame whether I have snapping enabled or not.
    Norman Willis
  • Jeff Schroeder
    August 26, 2010 at 2:18 pm
    Turn off “Quantize to frames” under the Options menu (alt-F8)
  • Norman Willis
    August 26, 2010 at 3:05 pm
    It is already off 🙂
    Norman Willis
  • Mike Kujbida
    August 26, 2010 at 3:12 pm
    Norman, that makes no sense whatsoever.
    Have you tried enabling and then disabling both options one or more times?
  • Norman Willis
    August 26, 2010 at 4:37 pm
    Yes, but maybe I am doing something wrong (it would not be the first time 🙂
    Please let me figure this thing with Noise Reduction in Sound Forge out, and then I will try to re-align the resultant Take 2’s.
    Norman Willis
  • Norman Willis
    August 26, 2010 at 9:06 pm
    >>Norman, that makes no sense whatsoever. Have you tried enabling and then disabling both options one or more times?
    Mike, I absolutely agree it makes no sense. Yes, I have tried various combinations of enabling and disabling.
    The H4N track slides smoothly. No issues at all. However, when I duplicate the audio track for Camera B Take 2, trim a second or so off of the end, and also turn both Snap and Quantas Airlines off, it still wants to jump by whole frames, and also snap the final 3-4 frames.
    Should I report this as a bug on my hardware?
    Norman Willis
