Activity › Forums › Adobe After Effects › How can I get my flv/swf down to 48kb!?!?
  • How can I get my flv/swf down to 48kb!?!?
    Posted by Gareth Harwood on November 19, 2010 at 10:31 am
    Hello all
    I have created a short animation (15 secs) with sound for use as a web ad. At the last minute the client has asked that i deliver it as a 48kb swf or flv. When exporting from After effects the smallest I can get it without it looking awful is about 600kb.
    Having done a bit of reading it seems i’ll need to rebuild it in flash to get it this small. Problem is I don’t know Flash too well and i’m sure it doesn’t have some of the key tools i’ve been relying on in AE(puppet tool, time remapping).
    Is there anyway I can do this without learning a new program and starting from scratch?
    I have tried the xfl export thing and this doesnt recognize anything in seperate layers and just exports a single flv or png sequence depending on what i choose.
    Any help on this would be really appreciated.
    Gareth
    Gareth Harwood replied 15 years, 6 months ago 3 Members · 3 Replies
  • Chris Wright
    November 19, 2010 at 6:15 pm
    you need to get Sorenson Squeeze. It also has a secret smoothing feature that can interpolate 12fps into 24fps.
    here’s a webpage that lists all the ways that you can compress.
    https://www.freeopenbook.com/flash8-bible/BBL0166.html
    https://technicolorsoftware.hostzi.com/
  • Ryan Hill
    November 19, 2010 at 6:43 pm
    You can export a small flv file if the animation is limited in certain ways. Any 3D layers or layers with filters applied, will be converted into an image per frame, which makes it larger. If you take a still image and apply just 2D position and scale animation to it, it will only need to store the one image + the animation data, which will be really small.
  • Gareth Harwood
    March 14, 2011 at 1:33 pm
    hi guys
    thank for all your responses but unfortunately I had the much bigger problem of my computer breaking to stop my progress. I didn’t manage to get the film that small but that has passed and hopefully i will never have to make such a small video again.
    cheers
