Activity Forums Apple Final Cut Pro How can I find why Control-Cmnd-S, the theoretical shortcut for the saturation panel in color correction, has “System Reserved” next to it in the command editor?
  • How can I find why Control-Cmnd-S, the theoretical shortcut for the saturation panel in color correction, has “System Reserved” next to it in the command editor?
    Posted by Noam Osband on June 6, 2015 at 6:02 pm
    Today I discovered the keyboard shortcuts to go between the different panes in the color board. In theory, Cntrl Cmnd S should open the saturation panel. It doesn’t work. I looked in the command editor and I see it says “System Reserved” I went to my Mac system preferences and looked all my keyboard shortcuts and I even spent time browsing online…but i can’t figure out how to find what currently is holding Control Command S as a shortcut. Thoughts? How can I do that?
    Neil Paisnel replied 11 years, 3 months ago 3 Members · 2 Replies
  • Craig Alan
    June 6, 2015 at 8:10 pm
    https://support.apple.com/kb/PH18418?locale=en_US
    Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
  • Neil Paisnel
    June 7, 2015 at 8:53 am
    If I am reading correctlly, the OP has alresdy looked where that link suggests, SysPrefs, Keyboard , Shortcuts.
    A link embedded within the page previously linked to,
    https://support.apple.com/kb/PH18424?locale=en_US&viewlocale=en_US
    Suggests any conflicts will apoear with Yello Exclamationmark
    If that is not happening, then it sounds like a more deep routed cause.
    I’d maybe try using that short cut combo, wirh FVPX closed. All apps closefd and see what happens.
    Msybe the okd trick of creating a new user to see if it will work in FCPX when logged in as new user.
    That might at least pin diwn the issue to ‘System’ or User
