Activity › Forums › Adobe After Effects › How can i export a text animation with a transparent bg?
  • How can i export a text animation with a transparent bg?
    Posted by Jon Kuritz on December 18, 2006 at 11:30 pm
    i want to do a little text animation to put in the bottom right corner but i cant figure out how to get a transparent bg. can anyone help me?
    Jon Kuritz replied 19 years, 9 months ago 3 Members · 3 Replies
  • Michael Duff
    December 18, 2006 at 11:39 pm
    just make sure that there are no layers underneather your text layer. You can check the transparency by clicking on the channels viewer button on the bottom of your composition window. It’s the button with three coloured circles overlapping. Select alpha channel. Then you can see which parts of your composition are transparent.
    Then if you are happy you just need to make sure you render out with an alpha channel. Use the render queue, and in output module select a format that supports alpha channels (like quicktime animation, or TGA sequence) – then you just need to make sure that RGB+A is selected under the channels option.
    Also, if you are importing into something like FCP I normally choose straight alpha channel instead of premultiplied.
    Hope that helps, let us know if you have any more questions
  • Jonathan Pitzer
    Simply render the file as a quicktime file with the setting RGB+ alpha. If you used some quictime formats, they will not allow an alpha channel. Use the animation setting. It will work best for this purpose.
  • Jon Kuritz
    December 19, 2006 at 5:00 pm
    Alright cool. ill try that. thanx a lot guys
