Activity Forums Adobe After Effects Expressions How can I draw with the brush tool a line with perfect rectangolar section?
  • How can I draw with the brush tool a line with perfect rectangolar section?
    Posted by Deborah on January 3, 2006 at 11:31 am
    Hi everyone!
    I’m tryng to draw a line with the brush tool with rectangolar or square section.
    I entered the brush properties but I’m able to get only circular or elliptical section.
    May anyone help me?
    Thanks! Debbie.
    Deborah replied 20 years, 8 months ago 2 Members · 4 Replies
  • Vince Becquiot
    January 3, 2006 at 7:07 pm
    Make your first brush point, hold shift and make your second point, it will connect the 2 points.
    Vince
  • Deborah
    January 4, 2006 at 8:26 am
    Vince thanks for your reply.
    My English is not that good! I meant: how can I have the section of the brush “square”. Usually it’s circular.
    Can you still help me?
    Debbie!
  • Vince Becquiot
    January 4, 2006 at 5:53 pm
    Well, I don’t think you can actually make a square tip, just a flat thin one by changing the settings in the brush palette…
    May I ask why you need that particular tip?
    You may be able to achieve the same effect with a mask, stroke, or just a simple expression.
    Vince
  • Deborah
    January 7, 2006 at 10:09 am
    Vince, thanks for your reply!
    With the pen tool it is very easy to create curves thanks to “bezier”.
    How can I do the same when using the brush?
    Thanks! Debbie!
