Activity › Forums › Adobe Premiere Pro › How can I display a Rule of thirds guide/overlay
Posted by Dave Rogers on July 19, 2012 at 12:48 pmIs there a way to display/generate a rule of thirds guide or overlay in Premiere
Thanks for any advice
Tye Belcher replied 8 years, 1 month ago 3 Members · 6 Replies -
Ann Bens
July 19, 2012 at 1:58 pmYou can draw one in the Titler
You can make one in Photoshop
You can use the grid effect, save it as a preset and drop it on a transparant video.———————————————–
Adobe Certified Expert Premiere Pro
Adobe Community Professional -
Dave Rogers
July 19, 2012 at 2:02 pmThanks Ann
The grid effect would be ideal but I haven’t managed to get the grid effect to display a grid that lines up with the rule of thirds, perhaps its just me could you share your settings thanks
Ann Bens
July 19, 2012 at 2:12 pm -
Ann Bens
July 19, 2012 at 6:31 pmYou are most welcome. Ann
Tye Belcher
June 12, 2018 at 1:15 amA good way to do it is add a grid effect to a transparent video layer above your footage. Change the “Size from” option to “width and height sliders”. Then in width, make it a 3rd of whatever resolution you are shooting at, and same for height. For example, If I have a 1920 x 1080 composition, I would make my width a 3rd of 1920 (640) and my height a 3rd of 1080 (360). This will give you the right scale grid. From there, you center it on your comp and you are set. I would suggest making presets for your most common resolutions. Hope this helps!
