Activity › Forums › Maxon Cinema 4D › How can I cut and move certain parts in C4D ?
  • How can I cut and move certain parts in C4D ?
    Posted by Andrey Kozyrev on July 20, 2011 at 12:43 pm
    Hello, I can’t figure out how to cut my object so that I can have a part of it that I can move/rotate? I need to make some kind of a door in my object and animate it but I don’t know how to cut the part I need.
    I looked up knife tool tutorials but still didn’t get how to separate part from the “main” obj.
    Here is my object: https://s16.radikal.ru/i190/1107/63/e4878e0f83f4.jpg
    Thanks in advance.
    Andrey Kozyrev replied 15 years, 2 months ago 2 Members · 2 Replies
  • Randy Johnson
    July 20, 2011 at 1:27 pm
    Select the polys you want to copy and right click then choose Split. It will give you a seperate object with just those polys. THen you go back to the original object and delete those polys… they should still be selected. You should then go into point mode and optimize to get rid of the left over points.
    /Randy
  • Andrey Kozyrev
    July 21, 2011 at 2:22 pm
    Thank you so much 🙂
