Activity Forums VEGAS Pro how can I crop media directly rather than on a track (multicamera issue)
  • how can I crop media directly rather than on a track (multicamera issue)
    Posted by Tony Cerqua on February 3, 2020 at 2:19 pm
    Hi
    I have a multicamera (3 cam) project where I wish to apply a crop to 2 of the 3 tracks/clips before combining into a multi camera track. The project consists of 3 clips approximately 4 minutes long (one clip from each camera).
    Whilst I know I can crop once in the multicamera track, this isn’t ideal since I change the active camera every 6-7 seconds which means I’d have to crop approx 35 events.
    If I crop the individual tracks before combining for multicam I get the following warning “Such items (such as envelopes, effects, or motion) will be lost during this operation. Continue?”
    I note from this ( https://forums.creativecow.net/thread/24/957676#957676 ) thread that there could be a way to apply the crop to the source media possibly within the media window however I can’t figure out how to do this in Move Studio 15.
    If I right click on a clip in the media bin and choose Media FX-> “Vegas Crop” I get a pop up window with options for X and Y crop however it doesn’t resemble the “normal” pan/crop window and it doesn’t give you a preview of the footage so I’m not sure how I could use it. I also note that presets I’ve saved in the “normal” pan/crop tool aren’t available in the media fx crop tool.
    Tony
    Dimitrios Papadimitriou replied 6 years, 7 months ago 2 Members · 3 Replies
  • Dimitrios Papadimitriou
    February 7, 2020 at 4:19 am
    Once I created the pan crop setting I wanted then rendered the video and reimported it into the project to get around this.
  • Tony Cerqua
    February 7, 2020 at 10:33 am
    thanks for responding, I agree, exporting/rendering then re-importing seems to be the only way around this issue, unfortunately even the “render to new track” seems a little buggy, sometimes it works other times it exhibits strange behaviour like rendering only the first few seconds of video but rendering all the audio so you end up with a very strange looking new clip.
    Doing a full export though does work, just a little clunky. I hope we see this limitation addressed in future releases.
    Tony
    February 7, 2020 at 6:54 pm
    It’s for sure clunky, I only did once when I wanted to switch crop settings very frequently on a long static shot. One other thing you could do is divide all the clips, then CTRL Left click select the ones you want to have a certain pan crop setting so that you can paste the settings on all of them at once, but that’s probably more work.
