Activity › Forums › Adobe After Effects › how can I correct tracking without retracking entire video?
  • how can I correct tracking without retracking entire video?
    Posted by Jon Iverson on June 28, 2010 at 1:17 pm
    Hi Folks:
    I just finished trying to learn the basics of tracking and cloning in AE CS4. I was very impressed with the result, but the tracking isn’t perfect and the cloning over the original area loses its alignment at times. The misalignment isn’t severe and I’m wondering if I may be able to correct it without having to motion track the entire video all over again? How can go back to just those areas that lost alignment for a few seconds and get the cloning lined back up where it should be?
    Thanks in advance for your help.
    Jon
    Jon Iverson replied 16 years, 3 months ago 2 Members · 2 Replies
  • Anders Hattne
    June 29, 2010 at 2:51 pm
    KeyTweak might help you. Check out this video by Mathias Möhl:
    https://vimeo.com/2747516
    http://www.ardillamedia.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Jon Iverson
    June 29, 2010 at 5:18 pm
    Thanks! I think that suggestion will pretty much solve the problem. I did go back and correct using a different method, but took much time over what you suggest.
