Activity Forums VEGAS Pro How can I compress to fit to burn DVD using DVD Architect Pro 5.2?
  • How can I compress to fit to burn DVD using DVD Architect Pro 5.2?
    Posted by Hideaki Ogiwara on May 1, 2011 at 5:41 pm
    here is my problem to burn DVD with DVD Architect Pro 5.2. My data is 1h 50m and with top menu page it’s about 5.3 G so I couldn’t burn to DVD….
    Is this easy way to compress and burn the DVD which is only 4.7 G….
    Thank you very much.
    Mike Kujbida replied 15 years, 4 months ago 3 Members · 2 Replies
  • John Rofrano
    May 1, 2011 at 7:41 pm
    The easiest way is to render to AVI file and have DVD Architect figure out the correct bit rate for you. It will fit everything to the disc. The other way is to use a bitrate calulator. Just google for it and you’ll find several. They will tell you what bit rate you’ll need to sue to fit 1:50 on a single DVD.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Mike Kujbida
    May 2, 2011 at 12:24 am
    The other thing to keep in mind is that DVDA has a long history of incorrectly reporting file sizes.
    Check the sizes of your MPEG-2 and AC-3 files and, as long as they’re under the limit, ignore the warning from DVDA.
    Once you do this, it will continue as expected with no further interruptions.
