Activity Forums Adobe After Effects How can I change a Composition and all the layers and comps inside it to the same duration.
  • How can I change a Composition and all the layers and comps inside it to the same duration.
    Posted by Joshua Chaulk on July 10, 2014 at 7:07 pm
    I’ve imported a character I made in photoshop as a composition and there are multiple comps and layers inside the master comp for that character. When I imported the psd into my project it imported with a 15 sec duration when i need it to be a full minute. I tried just clicking ctrl + K with the psd composition selected and changed the duration but it only effected the master comp for that psd. is there a way to change the duration of all the layers inside the composition at the same time so i don’t have to spend a half hour doing all the layers individually?
    Win 7 (64-bit)
    After Affects CC(2014)
    Kevin Camp replied 12 years, 2 months ago 3 Members · 3 Replies
  • James Huenergardt
    July 10, 2014 at 7:36 pm
    Yes,
    However, if you have nested comps, you’ll have to change those individually.
    For all regular image or solid layers, select all, go to the end of the comp and press ALT + Right Bracket or OPTION + Right Bracket.
    All your layers will now be the length of the comp UNLESS you have nested comps or footage that isn’t long enough.
    Hope this helps.
    Reel Inspirations – http://www.reelinspirations.com
    Commercials, Dramas, Image Pieces, Documentaries, Motion Graphics
  • Joshua Chaulk
    July 10, 2014 at 8:12 pm
    [James Huenergardt] “nested comps”
    I assume nested comps are comps within a comp? Yeah I probably have like 40 layers and nested comps within the one comp… Guess I will have to do things the hard way.
  • Kevin Camp
    July 10, 2014 at 8:40 pm
    there is a default duration preference for still image import in after effects.
    the default usually uses the last created comp duration, but you can also set it to be a fixed duration. if you want to make sure the psd file imports in as a full minute, you can go to preferences>import and set the still footage value to 1:00:00.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
