Activity Forums Boris FX Particle Illusion how can i center abn emitter ?
  • how can i center abn emitter ?
    Posted by Erik on September 5, 2005 at 9:55 am
    is there a way i can position an emitter exactly at the point i want to, because i can
    Erik replied 21 years ago 2 Members · 2 Replies
  • Alan Lorence
    September 5, 2005 at 11:49 am
    There is no grid. You can do a few things.
    1) select the emitter name in the hierarchy so the position graph shows, then r-click in the position graph and select “reset”. This will put the emitter in the center of the stage
    2) With the position graph selected, press the “N” key. This will bring up the numeric entry for the emitter position, and you can enter the pixel coordinates that you want.
    Alan.
    wondertouch
  • Erik
    September 5, 2005 at 12:51 pm
    Thanks Alan for your great program and help.
    Will there be a minor upgrade in the near future?
